moving robot
Showing all 5 results
  • PivotPi Base Kit
    The PivotPi Base Kit is perfect for getting started with animated robot projects! Code anything in your world to move with 4 small servo motors and 2 large, powerful ones. This is a kit that includes the PivotPi board, battery pack, 2 large servo motors and 4 small servo motors. Now you can program your robotics, automation, and art projects to move!
    $39.99
  • PivotPi Board
    The PivotPi is a complete kit to turn anything in your world into a moving robot. The PivotPi is a servo controller for the Raspberry Pi. It can control up to 8 servos, allowing you to make projects that move, grab, dance, swing, wave, and many other motions. You can use the PivotPi to create robots, automate your home, make moving sculptures, and craft animatronics built with the Raspberry Pi. The PivotPi can be programmed using Python, Scratch, and many other programming languages.
    $17.99
  • Servo Motor for Raspberry Pi (Set of 2 Large)
    This is a set of 2 large servo motors that you can connect to the PivotPi to make your robots and projects rotate! The servos come with various plastic adapters for connecting to your robotics, automation, and art projects.
    $14.99
  • Servo Motor for Raspberry Pi (Set of 4 Small)
    This is a set of 4 small servos that you can connect to the PivotPi to make your robots and projects rotate! The servos come with various plastic adapters for connecting to your robotics, automation, and art projects.
    $17.99
  • PivotPi Starter Kit
    The PivotPi Starter Kit includes everything you need to get started building animated robot projects! This kit includes the PivotPi board, battery pack, 2 large servo motors and 4 small servo motors, Raspberry Pi, Ethernet Cable, Power Adapter, Wifi Dongle, and SD card.
    $99.99
