You are currently connected to the internet (not your GoPiGo).
If you’re seeing this page, you are not connected to your GoPiGo and most likely you are not connected to it over WiFi.
No problem! Here’s how to solve the problem:
- First, double check the directions here for connecting to the GoPiGo.
- Try connecting to “http://10.10.10.10” Sometimes your browser history or network may be interfering with the connection to DexterOS, this can help solve that problem.
- If you need more help, our forums are here.
Note: You may be running Raspbian for Robots. Raspbian for Robots software does not setup a WiFi signal to connect to. Raspbian for Robots is for advanced users. If you would like to install DexterOS for free on your SD Card, please see directions for this here.
